Perform this procedure to configure remote SPBM global parameters. SPBM uses the remote Intermediate-System-to-Intermediate-System (IS-IS) link state routing protocol to provide a loop free Ethernet topology that creates a shortest path topology from every node to every other node in the network based on node MAC addresses.
- Select SPBM Remote.
- Select the SPBM tab.
- Select Insert to create a remote SPBM instance.
- Configure the remote SPBM parameters.
- Select Insert.
SPBM Field Descriptions
Use data in the following table to use the SPBM tab.
Name |
Description |
Id |
Specifies the remote SPBM instance ID. |
NodeNickName |
Specifies a nickname for the remote SPBM instance globally. The value is 2.5 bytes in the format <x.xx.xx>. |
PrimaryVlan |
Specifies the primary SPBM B-VLANs to add to the remote SPBM instance. |
Vlans |
Specifies the SPBM B-VLANs to add to the remote SPBM instance. |
LsdbTrap |
Enables or disables a trap when the SPBM LSDB changes. The default is disable. |
IpShortcut |
Enables or disables SPBM IP shortcut state. The default is disable. |
SmltSplitBEB |
Specifies whether the switch is the primary or secondary vIST peer. The default is primary. |
SmltVirtualBmac |
Specifies a virtual MAC address that can be used by both peers. |
SmltPeerSysId |
Specifies the system ID of the SPBM SMLT for this remote SPBM instance. |
Mcast |
Specifies if IP multicast over remote SPBM is enabled. The default is disabled. |
McastFwdCacheTimeout |
Specifies the global forward cache timeout in seconds. The default is 210 seconds. |
Ipv6Shortcut |
Enables or disables SPBM IPv6 shortcut state. The default is disable. |
McastSpbPimGwControllerEnable |
Enables or disables ISIS PLSB Multicast SPB PIM Gateway controller. Disabled by default. |
McastSpbPimGwGatewayEnable |
Enables or disables ISIS PLSB Multicast SPB PIM Gateway. Disabled by default. |
StpMultiHoming |
Enables or disables MSTP-Fabric Connect Multi Homing. The default is disabled (false). |
BVlanOrigin |
Specifies the origin of the B-VLAN. The values are:
The default is dynamic. |
